Activity Forums Adobe Premiere Pro Custom Frame Rate
  • Custom Frame Rate
    Posted by John Riker on April 29, 2015 at 10:04 pm
    I have a video with a custom frame rate, 24.375. I need to keep it this way to keep the audio in sync. Trust me I’ve tried everything and it gets out of sync and don’t want to stretch/shrink the video. Premiere provides a pulldown only option to pick frame rate. Is there any way to have a custom frame rate like this selected manually in premiere?
    Thanks.
    JR
    John Riker replied 11 years, 4 months ago 3 Members · 6 Replies
  • Vince Becquiot
    April 29, 2015 at 10:11 pm
    Yes, right click on the clip, or select all affected clips. Go to Modify> Interpret Footage.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • John Riker
    April 29, 2015 at 10:15 pm
    Thanks for the reply. When I do that it already says “Use Frame rate from File 24.3800”. Which still isn’t right but on export they just have a pulldown and have to select one from the list.
    JR
  • Vince Becquiot
    April 29, 2015 at 10:36 pm
    If you are editing 24p, you can just set it as 23.976, that should be it. What was it recorded with, was the sound recorded separately?
    Vince
    Vince Becquiot
  • John Riker
    April 29, 2015 at 10:45 pm
    If I set it to 23.976 the video ends up being a minute plus different in length so then the audio is naturally off.
  • David Baud
    April 29, 2015 at 10:46 pm
    I am curious: where do you intend to play your movie with your “custom frame rate”. I believe most player out there will require a standard frame rate (23.976, 24, 25, 29.97, 30fps etc…) so I believe you will have to conform your clip to whatever standard you want to use… unless you are working on a custom application?
    David Baud
    Post & VFX
    KOSMOS PRODUCTIONS
    Denver – Paris
    http://www.kosmos-productions.com
  • John Riker
    April 30, 2015 at 12:01 am
    I’m just playing it thru a streaming media system to my xbox thru the network so don’t think there will be any issues. I’m OK with changing it, just how do I get the audio to sync up as well? Should I assume since the audio is just stereo and I can load it into premiere that exporting the entire clip with the audio everything should be adjusted appropriately?
    JR.
