  • Posted by Darren Lee on July 22, 2018 at 10:47 am
    Hi, I am using the following expression on the Scale property;
    ScaleInTime=1;
    [easeOut(time, inPoint, inPoint+ScaleInTime, [0], [transform.scale[0]]), easeOut(time, inPoint, inPoint+ScaleInTime,[0],[transform.scale[0]])];
    I also sometimes use Ease and Wizz on keyframed animations, but wondered how I would implement the below functions in the above script?:
    // Ease and Wizz 2.0.4 : inOutQuint : All keyframes
    // Ian Haigh (https://ianhaigh.com/easeandwizz/)
    // Last built: 2013-07-05T11:46:51+10:00
    // some defaults
    var p = 0.81; // period for elastic
    var a = 50; // amplitude for elastic
    var s = 1.70158; // overshoot amount for "back"
    function easeandwizz_inOutQuint(t, b, c, d) {
    if ((t/=d/2) < 1) return c/2*t*t*t*t*t + b;
    return c/2*((t-=2)*t*t*t*t + 2) + b;
    function easeAndWizz() {
    var n = 0;
    if (numKeys > 0) {
    n = nearestKey(time).index;
    if (key(n).time > time) { n-- }
    try {
    var key1 = key(n);
    var key2 = key(n+1);
    } catch(e) {
    return null;
    // determine how many dimensions the keyframes need
    var dim = 1; // It's gotta have at least ONE dimension
    try {
    key(1)[1];
    dim = 2;
    key(1)[2];
    dim = 3;
    } catch(e) {}
    t = time - key1.time;
    d = key2.time - key1.time;
    sX = key1[0];
    eX = key2[0] - key1[0];
    if (dim >= 2) {
    sY = key1[1];
    eY = key2[1] - key1[1];
    if (dim >= 3) {
    sZ = key1[2];
    eZ = key2[2] - key1[2];
    if ((time < key1.time) || (time > key2.time)) {
    return value;
    } else {
    val1 = easeandwizz_inOutQuint(t, sX, eX, d, a, p, s);
    switch (dim) {
    case 1:
    return val1;
    break;
    case 2:
    val2 = easeandwizz_inOutQuint(t, sY, eY, d, a, p, s);
    return [val1, val2];
    break;
    case 3:
    val3 = easeandwizz_inOutQuint(t, sZ, eZ, d, a, p, s);
    return [val1, val2, val3];
    break;
    default:
    return null;
    (easeAndWizz() || value);
    Thanks in advance
    Darren Lee replied 8 years, 1 month ago 3 Members · 5 Replies
  • Darren Lee
    July 23, 2018 at 1:16 pm
    I might not have been clear on this, I want to achieve something like:
    ScaleInTime=1;
    [easeandwizz_inOutQuint(time, inPoint, inPoint+ScaleInTime, [0], [transform.scale[0]]), easeandwizz_inOutQuint(time, inPoint, inPoint+ScaleInTime,[0],[transform.scale[0]])];
  • Darren Lee
    July 23, 2018 at 2:24 pm
    In case anyone is interested, I found an example here: https://gist.github.com/monsieuroeuf/6051422
  • Kalleheikki Kannisto
    July 23, 2018 at 2:25 pm
    I was gonna suggest just putting in those two keyframes, but looks like you found a solution.
    Senior Graphic Designer
  • Alex Printz
    July 23, 2018 at 2:34 pm
    It would look something like this. Note that I stripped out all of the ease&Wizz dimension checks because you are only providing the X-value scale in your linear functions.
    If you wanted to update the bezier animation functions, all you need to do is change the “easeandwizz_inOutQuint” function.
    // some Ease & Wizz defaults
    var r = 1; //aka scaleInTime
    var x = value[0];
    o = easeAndWizz();
    [o,o]
    if ((time < inPoint) || (time > (inPoint + r))) {
    return x;
    } else {
    return easeandwizz_inOutQuint(time - inPoint, 0, x, r, a, p, s);
    Alex Printz
    Mograph Designer
  • Darren Lee
    July 23, 2018 at 3:40 pm
    Thanks all. I modified monsieuroeuf’s version and came up with the below. It scales in and out nicely without keyframes, you’d just replace easeandwizz_inOutQuart with which ever Ease and Whizz function you prefer
    fadeInTime=1.5;
    scaleFromTo=50;
    function easeandwizz_inOutQuart(t, b, c, d) {
    if ((t/=d/2) &lt; 1) return c/2*t*t*t*t + b;
    return -c/2 * ((t-=2)*t*t*t - 2) + b;
    initialScale = transform.scale[0];
    if (time &lt; (inPoint+outPoint)/2){
    moveEnd = inPoint+fadeInTime;
    diff = initialScale-scaleFromTo;
    normalisedTime = linear(time, inPoint, inPoint + fadeInTime, 0, fadeInTime);
    s = easeandwizz_inOutQuart(normalisedTime, scaleFromTo, diff, fadeInTime);
    }else{
    moveEnd = outPoint;
    diff = scaleFromTo-initialScale;
    normalisedTime = linear(time, outPoint-fadeInTime, outPoint, 0, fadeInTime);
    s = easeandwizz_inOutQuart(normalisedTime, initialScale, diff, fadeInTime);
    [s, s]
