Activity Forums Adobe After Effects Expressions Custom ease via an Expression or copy ease from keyframes to expression
  • Custom ease via an Expression or copy ease from keyframes to expression
    Posted by Jacob Resch on July 13, 2018 at 11:59 am
    Hi there,
    I want to automate the Position of a Text Layer via markers.
    That already works via the expression below
    But instead of easeOut i want a custom ease.
    I already have the ease i want on some keyframes, but is t here a way to convert that specific ease into an expression i could then use here instead of easeOut ?
    Or reference these keyframes in the expression and let the expression only use the ease of these keyframes.
    Is that possible ?
    Any help is appreciated! Thank you :)!
    zeit = framesToTime(20,25)
    sx = 62.25; // slide distance
    sd = zeit; // slide duration
    m = thisLayer.marker;
    y = 0;
    if (m.numKeys > 0){
    n = m.nearestKey(time).index;
    if (time < m.key(n).time) n--;
    if (n > 0){
    t = time - m.key(n).time;
    y = easeOut(t,0,sd,(n-1)*sx,n*sx);
    value + [0,-y]
    Alex Printz replied 8 years, 2 months ago 2 Members · 1 Reply
  • Alex Printz
    July 16, 2018 at 2:20 pm
    You would need to create some additional lines of code to convert a variable over time into your values. If you had something keyed, you could measure the first and last keyframes and scale proportionately to the keyframe value.
    You could also write a bezier equation to pass the value through.
    Then use the output of your equation/property scale as an input on a linear function.
    I can’t be more specific than that because we have no idea of knowing what your easing output looks like.
    -Alex
