Activity Forums Adobe Photoshop custom color channels
  • custom color channels
    Posted by Jason Rutledge on June 30, 2005 at 3:21 pm
    I’ve been trying to figure out a solid way to generate custom color separations of an image. Sort of like taking an RGB image and separating it out into CMYK only instead of Cyan or magenta I want to get, say, an orangish-brown channel or a bluish-grey channel.
    Any ideas?
    Jason Rutledge replied 21 years, 2 months ago 2 Members · 2 Replies
  • Kelly Johnson
    June 30, 2005 at 4:33 pm
    Well, if you want three channels, use RGB and then color shift as necessary to achieve your results.
    If your channels are the colors you mention above, however, it’s going to generate some wacked colors in the final images.
    Are you trying to take a channel and use it’s information for an actual image?
    You can also use the various channel ops (add/sub/multiply etc) and create a new channel using the C and M in cmyk for instance and then just delete the C and M channels.
    Why do you need to do this? Maybe if we knew what your end result is going to be, we could get a better answer for you.
  • Jason Rutledge
    June 30, 2005 at 4:58 pm
    Think of it like separating an RGB image into spot colors for screenprinting. If there’s an orange-brown color in the image, I’d be separating out a screen just for that color. I’m taking RGB images of natural stone and separating out the natural stones colors for screenprinting. It’s usually a four-screen process with one screen being, for example, a light-beige, the second screen a maroon shade, the third a greyish color, and the fourth a dark brown.
    There was a plug-in made by a company in Spain called inedit Multicomia, but it never got out of beta and never really did anything without crashing.
    jason rutledge
