Activity Forums DaVinci Resolve Custom aspect ratio/frame size exporting out of Resolve
  • Custom aspect ratio/frame size exporting out of Resolve
    Posted by Carl Thelin on April 30, 2017 at 6:56 am
    I am editing a video ad intended for use on mobile social media, and we want an aspect ratio of about 1.1 so it is more eye-catching than a wider frame would be. I shot the ad in standard 1920×1080 HD. I did an initial edit in FCP X just to get the clips in place then exported to DaVinci Resolve 11 in the same resolution/ratio. I want to complete the project in Resolve and export directly out of it in 1190×1080 resolution, and the program seems to have functionality that should allow me to do this but when I try, The resulting export places my cropped image in a much larger black frame that seems to be preserving the original 1920 width. Any ideas as to what I am doing wrong or how to fix this?
    Glenn Sakatch replied 9 years, 4 months ago 2 Members · 1 Reply
  • Glenn Sakatch
    May 1, 2017 at 1:59 pm
    That image above doesn’t look like its 1920 width, unlesss its an optical illusion. It looks like the same aspect ratio as the clip inside it, but just a bigger frame. The above image looks like you could scale it up to fill the black pretty much.
    Are you sure your original clip is 1190 x 1080.
    Check your output scaling in your preferences, as well as your mismatched resolution settings.
    Glenn
