Activity Forums Adobe After Effects Expressions Custom Arrays on certain properties problems
  • Custom Arrays on certain properties problems
    Posted by Alex Mann on September 2, 2013 at 3:52 pm
    Hi there,
    A bit confused with the error message I get when trying to write expressions for certain properties (in this case ‘Position’).
    Starting out with something like:
    myArray = [5,6,7,8];
    returns an error:
    “expression result must be of dimension 2, not 4 Expression disabled.”
    Whilst I get that 2D position in After Effects is [x,y], I don’t understand why I can’t define my own array as part of the expression.
    Thanks in advance 🙂
    Alex Mann replied 13 years ago 2 Members · 2 Replies
  • Todd Kopriva
    September 2, 2013 at 4:20 pm
    You can define your own arrays all you want, but the expression still needs to evaluate to a value that has the correct dimensions for the property that it’s on.
    After Effects team blog
  • Alex Mann
    September 2, 2013 at 4:29 pm
    Thanks Todd,
    Just this minute discovered the same thing myself. Basically writing an array and nothing else, so the expression had nothing to evaluate to. Duh 🙁
    Cheers though
