Activity › Forums › Apple Final Cut Pro › Custom 8-Point Mask effect ending sooner than clip
Posted by James Culbertson on July 20, 2011 at 6:34 pmI’ve got the 8-Point Mask (Custom Effect) that someone here created in Motion applied to a clip. The 8-Point Mask cuts out 10 frames earlier than the end of the clip. I can still see the mask points in the last 10 frames, but no effect.
Other Custom Effects do not appear to have this issue so far.
Any suggestions?
James Culbertson replied 15 years, 1 month ago 3 Members · 5 Replies -
Brendan Gibbons
July 20, 2011 at 9:41 pmDo you have motion installed to open the effect up and inspect it?
Sounds like one of the layers in motion has possibly been trimmed a few frames short of the total duration.
There are a couple of 8 point masks floating about:
https://alex4d.wordpress.com/2011/06/30/free-final-cut-pro-x-effect-mask-8-points-alex4d/
https://f1.creativecow.net/2557/8point-mask
See if either of these two sort out your problem.
Cheers,
Brendan
Matthew Schickler
July 20, 2011 at 10:25 pmYeah, I bet I mucked up the length of a layer somewhere. I’ll take a look at it when I get home tonight. Kind of glad someone is actually using it!
James Culbertson
July 20, 2011 at 11:25 pmSeems like this brings up an issue of versioning and ownership. Should we as a community try to establish a way of identifying effects?
For instance having a text file in the effect folder that identifies the creator, creation date, version number, and even parameters that it includes…
Brendan Gibbons
July 20, 2011 at 11:44 pmGood idea this. Especially if people go on to sell presets, it would be a good practise to include creator and version details in some sort of readme file in the download.
Version details and any fixes could be outlined, and also installation details of the effect included.
A sample useage of the preset could be outlined as well.
With so many good presets already out there in only one month it is already getting hard to keep a track of them all…tough problem to have I know 😉
I’ve been guilty myself of putting presets out there without much info, but I am looking into tidying it up a bit and including more information.
Cheers,
Brendan
James Culbertson
July 20, 2011 at 11:56 pmDo you want to confer with some of the other prolific creators of custom effects and come up with some kind of voluntary standard for this?
Then propose it to the community for feedback…?
