Activity › Forums › Adobe Illustrator › Curving a path in Illustrator
  • Curving a path in Illustrator
    Posted by Bruce Critelli on July 5, 2005 at 3:06 pm
    In illustrator, when you have straight path, line segment, etc, and you want to curve it to make an arc, what method do you use? In Freehand you could just use the subselect tool; but I can’t figure it out in Illustrator.
    Andrei Lutic replied 21 years, 2 months ago 2 Members · 1 Reply
  • Andrei Lutic
    July 6, 2005 at 4:56 am
    You must use the convert anchor point tool and drag from the end points of the path to convert them in bezier points. But I guess the best thing, if you need a curved line, is to draw it curved from the begining.
