Activity › Forums › Adobe After Effects › Curves in AE CS3
  • Curves in AE CS3
    Posted by Anthony Pinskey on December 16, 2008 at 4:08 am
    Hey i gotta quick question. Is it possible to add the curves effect to every single layer without doing it manually? i wanted to take a preset i made and add it too all the layers i have. thanks for any input!
    – Anthony
    Roland R. kahlenberg replied 17 years, 9 months ago 3 Members · 2 Replies
  • Jon Geddes
    December 16, 2008 at 6:59 am
    If all the curve adjustments are the same, then you can add an Adjustment Layer above all the layers, then apply the curves to the adjustment layer.
    Jon Geddes
    Motion Graphics Designer
    http://www.precomposed.com
  • Roland R. kahlenberg
    December 16, 2008 at 2:34 pm
    [Jon Geddes] “If all the curve adjustments are the same, then you can add an Adjustment Layer above all the layers, then apply the curves to the adjustment layer.”
    OR
    Save your Curves setting as an Animation Preset. Then select multiple layers and with one go, you can a/pply the saved Animation Preset to all the selected layers. Just be certain that your Curves setting is ideal for all the layers. Chances of this being true is highly improbable, unless your applying the preset to CG. Therefore, be prepared for some tweaking.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
