Activity Forums DaVinci Resolve Curves Adjustments
  • Curves Adjustments
    Posted by Eric Rosen on August 26, 2011 at 3:53 am
    I have been using curves quite a bit to do quick hue rotation or do global desat on a hue.
    I had a shot in which I did a curves hue rotation then had to made a dynamic in the dynamics timeline.
    I swung the hue on the curves adjustment on the other side of the dynamic. When I play that back the
    hue rotation pops and does not dissolve from one setting to the next. I can see that curves are absent from the dynamics timeline, so should I assume you cannot do dynamics with curves adjustments?
    Eric Rosen
    Lightpress Inc.
    http://www.lightpress.tv
    p. 206.462.4717
    Jake Blackstone replied 15 years ago 2 Members · 1 Reply
  • Jake Blackstone
    August 26, 2011 at 5:32 am
    That’s correct. None of curves allow for dynamic keyframing.
