Activity › Forums › Media 100 › Curve issue
  • Curve issue
    Posted by Michael Lang on March 1, 2007 at 6:27 pm
    After doing many color corrections on a video using the curves tool, the tool button suddenly greyed out.
    It has never done that before. It does work with clips in the bin though.
    Media 100 7.5/G4/OS9
    Floh Peters replied 19 years, 7 months ago 2 Members · 1 Reply
  • Floh Peters
    March 1, 2007 at 6:31 pm
    The Pre-V8 systems had a limit to ColorFX that could be used in a timeline; I think it was 50 different Curves/Levels settings combined per timeline. So probably you have used more than 50 different settings. If you use similar settings on clips make sure that you create a preset and use this, since you can use a preset as often as you like.
