Activity Forums Adobe Illustrator Curve display accuracy
  • Curve display accuracy
    Posted by Nick Hill on November 29, 2011 at 5:52 pm
    I’m probably being an idiot here, but I’ve drawn some paths with a Wacom tablet and they don’t display smoothly. They print out like this too. I can’t find anything in Settings to up the interpolation or curve resolution – any ideas? You can see the path on the full-size image and it’s smooth like it oughta be….
    Nick Hill replied 14 years, 6 months ago 2 Members · 2 Replies
  • Vincent Rosati
    November 29, 2011 at 6:23 pm
    I suspect that it’s that you need more points on your path, to improve the rendering of the brush.
    You could double-click on the Paintbrush or Pencil tool in the palette to adjust the tool settings. Or for paths that already exist, Object / Path / Add Anchor Points.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Nick Hill
    November 30, 2011 at 2:09 pm
    Ah, adding extra curve points works great – thanks. Oddly enough, I also tried changing the brush (using the original path) and it looks fine, so maybe it’s the brush I was using that wasn’t rendering properly.
