Activity Forums Maxon Cinema 4D Curtain with clothilde
  • Curtain with clothilde
    Posted by Matthias Gottung on January 19, 2008 at 1:21 am
    Hey,
    I’m currently trying to make a curtain in c4d with clothilde and collider tags that should look something like this
    https://img254.imageshack.us/img254/2631/vorhangnf5.gif
    I have a plane (the curtain) and 2 collider cylinders, i move the cylinders upwards to shape the curtain
    but I’m having problems with it looking a little too blocky,
    when I crank up the subdivisions of the plane or the clothnurbs it’s not really looking better
    Any help?
    I don’t really need it to be animatable
    with kind regards
    Matt
    Randy Johnson replied 18 years, 8 months ago 2 Members · 3 Replies
  • Randy Johnson
    January 21, 2008 at 9:03 am
    Try using the belt option…you get more control than colliders.
    You will still need the colider on the cutan rod though.
    /randy
  • Matthias Gottung
    January 23, 2008 at 1:33 am
    Hey Randy,
    So I should try to use the hover or influence map?
    Well, I’ll read up on how to create vertex maps
    thanks
    Matt
  • Randy Johnson
    January 23, 2008 at 9:22 am
    Have you tried fixing the bottom row of points and turning up the wind power and direction (cloth tag:forces)? Then your sword/cylinder collider is at the same Y axis as the bottom row of points.
    I also got the effect by using a belt from the bottom points and connecting to a cube that i then key framed to wrap up and over the curtan rod. This method took far more effort to get the hanging look.
    /good luck,
    Randy
