Activity › Forums › Apple Final Cut Pro Legacy › Cursor spins about 15 minutes on every move
  • Cursor spins about 15 minutes on every move
    Posted by Jack Fox on May 3, 2010 at 11:42 pm
    I have a total of two hours of quicktime clips (Maybe 10 separate clips) in a sequence with few effects, a stereo track and a a few transitions. It is driving me buggy. Every time I attempt a change, like move to the next frame with the forward or back arrow, the cursor spins for 15 minutes. I have plenty of hard drive space 8gb of ram, FCP6, two cpu’s and it just chokes up with every move. What kinds of things can cause this, where do I begin checking?
    jmf
    Jack Fox replied 16 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    May 4, 2010 at 3:33 am
    [jack fox] “I have a total of two hours of quicktime clip”
    What codec? .Mov is not a codec…just to head that off at the pass. Look at the EASY SETUP in the Final Cut Pro menu…THOSE are codecs. So, what is the codec of all these clips. FCP doesn’t just work with any old QT files you throw at it. It likes codecs that are designed for editing…and gags on ones that aren’t.
    Sounds like your FCP is gagging.
    Shane
  • Michael Gissing
    May 4, 2010 at 4:58 am
    Also what hard drives are you using. I hope your media is not on the internal system drive or a USB 2.
  • Matt Lyon
    May 4, 2010 at 1:00 pm
    This could also be a serious I/O issue. I had this happen to me recently with an external FireWire drive that was on it\\\’s last legs. The drive would still mount and appear in the finder, but would flood the bus with read/write errors. I don\\\’t even think I was playing media off it, but it was still chocking FCP.
    Also, make sure you aren\’t connected to any servers or other machines on your network, in the off chance FCP is trying to find media on a remote drive (unless you are specifically using a SAN Or similar).
    Matt Lyon
    Editor
    Toronto
  • Jack Fox
    May 4, 2010 at 11:58 pm
    -Whoops, you make it sound like bad thing, is there an easy way move media to another internal drive and save the cache?
    -Is there a way to check a drive to see if there are IO errors?
    -Below is a copy of my sequence settings:
  • David Roth weiss
    May 5, 2010 at 12:13 am
    Jack,
    See where it says “MPEG-4?”
    That’s indicates you’re trying to edit a non-realtime codec, which just also happens to be a delivery codec in FCP, not an editing codec. You have to transcode all of those clips to an editing codec before you start to edit with them in FCP. There are a zillion posts on the subject if you do a search.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Jack Fox
    May 5, 2010 at 2:06 am
    Thanks, all I need to do is find a good transcoder. I used iskysoft to make the clips so I’ll start with them.
    jmf
  • Jack Fox
    May 12, 2010 at 12:08 pm
    I tried some things and no luck, it seems the problem starts after I render the timeline. Once the project is rendered every move of the playhead requires 10 minutes of cursor process time.
    jmf
