Activity Forums Adobe After Effects Expressions Cursor for Type On Effect
  • Cursor for Type On Effect
    Posted by Aaron Williams on April 27, 2022 at 3:40 pm
    It sounds simple but I’m having a hard time getting this to work right. I just want a non-blinking cursor to wright on text, often in multiple lines. Then the option of the cursor to erase it all again. I have gotten real close using a few methods. This one I think give the most flexibility for what I want to do.
    The problems are with line breaks in paragraph boxes: The text will start typing on the first line until in runs out of room then jumps the current word to the second line and finishes typing. I could manually add a line break, but it then breaks the cursor because line breaks must count as a character and throws the whole thing off.
    I’m not that hip on the programing. I took a blinking cursor script and changed it enough to replace the empty space with the same character. Don’t make fun of me too bad 😉
    Source Text
    var sign = "|";
    var blinkInterval = 15;
    var i = effect("Text")("ADBE Slider Control-0001");
    var on = effect("On/Off")("ADBE Checkbox Control-0001");
    var frames = timeToFrames(time);
    var check = frames / blinkInterval;
    if (on == 1) {
    if (i.valueAtTime(time + thisComp.frameDuration) > i){
    end = sign;
    } else {
    if (Math.floor(check) % 2 == 0) {
    end = sign;
    } else {
    end = "|";
    } else {
    end = " ";
    text.sourceText.substr(0,parseInt(i)) + end;
    Range Selector 1 > Start
    text.animator("ADBE Text Animator")("ADBE Text Selectors")("ADBE Text Selector")("ADBE Text Index End") - 1;
    Range Selector 1 > End
    text("ADBE Text Document").length;
    In the Effects there is the Slider, Checkbox, and Color picker.
    Any help would be great. Thank you!
    AARON
    Aaron Williams replied 4 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
