Activity › Forums › Adobe After Effects › Curling Text around 3D tubing
  • Curling Text around 3D tubing
    Posted by David Rickles on September 16, 2006 at 5:28 am
    So I have begun to see this a lot, and it’s something that has been eluding me for a while…I need to create text to move on a 3D curved path so that it will rotate with and around 3D circular objects. How do I make the text bend to the shape of the 3D curves? I’m good on the rotation with anchor points, etc…but I just can’t figure out the curling part. Please, someone, relieve my headache!!!! Thanks!
    David Rickles
    Producer, Editor, Animator
    David.Rickles@gmail.com
    Mike Clasby replied 20 years ago 4 Members · 3 Replies
  • Alexxx
    September 18, 2006 at 4:30 am
    Not sure I understand your problem entirely, but if I may assume that you have an object layer with something on it (say a picture of a beachball) and you want the text to go around it.
    Create a text layer and apply CCSphere to it. Blow up the radius so it’s bigger than the ball. You can then rotate the sphere to move the text in a circular fashion. To make it appear infront and behind the ball, duplicate the text layer and then on each CCSphere you can make it render the outside and inside of the sphere. So the outside one sits above the beachball, the inside on behind. Now if you rotate the two CCspheres in unison, it looks like the text goes around the beachball.
    Hope this makes sense.
    Alex
    http://www.lightdrop.com.au
  • Steve Roberts
    September 18, 2006 at 4:59 am
    You might want to check out a “ribbon” tutorial on the COW by David Langley, or a Zaxwerks “filmstrip” tutorial by Serge Hamad.
    However, both those methods are limited, since AE’s 3D capabilities are limited. If you want more flexibility, use a real 3D app … which was probably used for the spots you’ve seen. 🙂
  • Mike Clasby
    September 18, 2006 at 9:32 am
    Alex’s is the easiest and best for text around a beachball or globe, but if you have many objects in AE 3D you might look at this answer just below:
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=887210
