Activity Forums Adobe After Effects Curious Composition size
  • Curious Composition size
    Posted by Gabi Bucataru on September 3, 2011 at 4:14 am
    Hi Gang –
    Be gentle – first poster in here. But take this:
    I am importing a HDV clip that has the following settings into AE CS5:
    1440×1080 (1.33), Separating (Upper)
    29.97 fps
    HDV 1080i60
    … and when I am dragging it over the Make New Composition” icon, the composition looks more like a 4:3 ratio and I have no way of changing that for the clip to look normal unless I set the composition to 1920×1440 (using Square pixels).
    Also by default I cannot create a new composition using the 1440 x 1080 size (an square pixels) – the “Lock Aspect Ratio” always shows 4:3 (1.33)…
    Am I doing something wrong??
    Thanks!!
    Gabi
    Gabi Bucataru replied 14 years, 12 months ago 3 Members · 3 Replies
  • Darby Edelen
    September 3, 2011 at 12:51 pm
    [Gabi Bucataru]
    29.97 fps
    HDV 1080i60″
    The HDV footage has a pixel aspect ratio of 1.33. It is not square pixel. You either want to use the HDV 1080 composition preset and make sure that you view with pixel aspect ratio correction turned on (it’s a composition viewer switch), or you want to put the clip in a 1920×1080 square pixel comp.
    Darby Edelen
  • Ben G unguren
    September 3, 2011 at 3:49 pm
    I’d go with setting up a comp that is 1920×1080 pixels, with a Square (1.0) pixel aspect ratio. When you drag in your 1440×1080 footage, press command+opt+f (ctrl+alt+f) to make it fit to the composition.
    In my opinion, it’s a good rule of thumb to work in square pixels — things are less likely to get messed up….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Gabi Bucataru
    September 6, 2011 at 3:06 pm
    Darby and Ben –
    Thanks for your responses – Placing the clip in a 1920×1080 square pixel comp solved the issue (using the square pixel setting).
    Also I choose that same setting to render the final clip – to be used later in FCP –
    Thanks a bunch!
    Gabi
