Activity Forums Apple Final Cut Pro Legacy Curious about AVI 720×480 and pixel aspect ratio
  • Curious about AVI 720×480 and pixel aspect ratio
    Posted by Anne Martin on June 16, 2009 at 7:46 pm
    I’m just curious, is it possible to make a 720×480 AVI with DV pixel aspect ratio? When I export a 4:3 720×480 clip as an AVI and open it with Quicktime the format is DV, 720×480 but the actual size is 640×480. I take this to mean that the AVI is using square pixels to display properly on a computer monitor.
    Is there any way to even make an AVI with actual size of 720×480 and would someone ever need to?
    -Anne
    Anne Martin replied 17 years, 2 months ago 2 Members · 2 Replies
  • Chris Borjis
    June 16, 2009 at 11:03 pm
    720×480 D1 is a “semi” anamorphic format.
    the pixel ratio is 0.9
    viewed at its proper display ratio of 1.0 its 640×480
    720×480 D1 Widescreen is “full” anamorphic. (exactly like anamorphic dvds for example)
    the pixel ratio is 1.2
    viewed at its proper display ratio of 1.0 its 854×480 (letterboxed on 4:3 or filled on 16:9)
    here endith the lesson.
  • Anne Martin
    June 17, 2009 at 2:05 pm
    Thanks for the responses,
    Dave, it is also 640×480 but with square pixels aspect ratio.
    By the way, everything looks right. Our client just asked for 720×480 and I’m a little worried if they open it up in QT and see that “actual size” as 640×480 they won’t understand that the frame size is just adjusting for the display ratio. But it sounds like that’s what I’ll have to say.
