Activity Forums Apple Final Cut Pro Legacy Cupturing Redundant Audio Tracks
  • Cupturing Redundant Audio Tracks
    Posted by Grant Walls on May 10, 2010 at 4:46 am
    Hi Guys,
    My capture settings are setup so FCP captures 16tracks of audio. I only need two. The rest have no sound at all, but I can’t change the capture preset.
    Can anyone tell me how to change it. I’ve tried changing it the capture preset window, but the pull down menu has no other option. See pics.
    Anyone had this problem and solved it?
    Cheers,
    Grant
    Chris Borjis replied 16 years, 4 months ago 3 Members · 2 Replies
  • Adam Taylor
    May 10, 2010 at 7:58 am
    You specify the number of audio channels in the Log & Capture window. Top right hand corner of the pop-up, hit the Clip Settings tab and then enter the desired number of audio tracks.
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
  • Chris Borjis
    May 10, 2010 at 8:22 pm
    just to add if your running final cut 6.x, there was a problem where it would reset to all audio tracks again, very annoying but fixed in final cut 7.
    fyi
