Activity › Forums › DaVinci Resolve › cudart64…dll missing Resolve on Windows won’t run
  • cudart64…dll missing Resolve on Windows won’t run
    Posted by Andrew Stone on August 16, 2012 at 12:57 am
    Have a Windows box following BM recommended parts for a Resolve machine.
    Of note are two video cards:
    Quadro 4000 as UI card and GTX 580 for processing.
    I have the latest drivers installed, 301.42
    but I get the following error when I attempt to boot up Resolve:
    “cudart64_40_17.dll is missing.”
    Seems this isn’t the first time this has happened but the solution offered is to do some dll hacking. I would rather not do that.
    Any suggestions?
    -Andrew
    Andrew Stone replied 14 years, 1 month ago 2 Members · 3 Replies
  • Andrew Stone
    August 16, 2012 at 2:12 am
    Solved the dll problem by moving from 8.2.2 to the 9 beta but introduced the known “Quicktime Decoder initialization failed” problem.
  • Rohit Gupta
    August 16, 2012 at 2:26 am
    Can you please make sure you are installing V9. Don’t make copies of the program files binary, that’s not going to work. You can’t have both 8.2.2 and 9 on the same system installed at the same time. Uninstall both first if you are not certain of the history of the installation.
  • Andrew Stone
    August 16, 2012 at 2:36 am
    Hi Rohit,
    Thanks for the quick response. When each issue came up I performed a proper uninstall before installing anything else.
    When I had the issue with the dll in 8.2.2, I did not have 9 beta installed. I tried several times to uninstall and reinstall but to no avail.
    When installed 9 beta, I first performed an uninstall of 8.2.2 for fear of dependencies stomping on each other. When I got the quicktime problem, I uninstalled both Quicktime and Resolve 9 and then did a reinstall of 9 which then prompted the install of QuickTime. Still got errors.
    Just did a reboot (second time since last install and now the Quicktime error is gone.
    I recall a mod on this sub-forum stating that both 8.2.2 and 9 cannot live on the same machine. I have the beta working now so I am not going to tempt fate.
    -Andrew
