Activity › Forums › Adobe Premiere Pro › CUDA update causes Premiere Pro 7.2.2 to crash on startup!
  • CUDA update causes Premiere Pro 7.2.2 to crash on startup!
    Posted by Tom Laughlin on October 15, 2014 at 1:24 am
    Hello everyone,
    An editors worst nightmare. I have an ATI Radeon Card 5770, in my 2008 MacPro, running OS 10.7.5, and I’ve got a 2 x 2.66 Ghz Dual-Core Intel Xeon, with 16 GB Memory, so yes, it’s a bit older, but I’ve updated ad upgraded it, works fine for my needs.
    I was running an update on my “Cuda” driver from Cuda driver v5.0.45 to 5.5.45, and after the upgrade, Premiere Pro 7.2.2 would not boot up. It would quit on start up. Very Very Scary!
    So, I went back to the Cuda website and downloaded and re-installed v5.0.45, and now, Premiere Pro starts up fine, no problems at all, thank heavens!
    Can anyone give me any ideas what’s going on or what this is all about? When I finally finish my edits in 7.2.2, I plan on moving to Premiere 8.0.1, just don’t want to upgrade mid-projects, so.
    Tom
    Tom Laughlin
    Producer/Editor
    Digital Chop House
    Salt Lake City, Utah
    http://www.digitalchophouse.com
    Tom Laughlin replied 11 years, 11 months ago 4 Members · 6 Replies
  • Dennis Radeke
    October 15, 2014 at 10:54 am
    Hi Tom,
    I’d guess that it has to do with the fact that you don’t have a CUDA card in the system – or at least what you described in the thread. CUDA is only for NVIDIA cards, you said you have an AMD/ATI card which would use OpenCL.
    HTH,
    Dennis
  • Tom Laughlin
    October 15, 2014 at 2:36 pm
    I guess my next question would be don’t you have to have some form of cuda or a cuda driver installed to run Davinci Resolve, or when you install DR, doesn’t it automatically place a cuda driver on your Mac? I read on a forum about someone saying this is how DR mounts from cuda or from off a detected cuda driver? I also read on another forum where people deleted the cuda framework folder from in their library on their Mac and that helped, but I’m nervous not to delete any library framework folders on my Mac risking functionality issues. As long as I don’t upgrade my cuda driver to the newest driver, premiere runs ok as before, but like I mentioned, it doesn’t make sense anyways, cause I don’t have a nvidia card anymore, I’ve got an ATI 5770 inside.
    There is a problem I’m having with detecting a newly added 3rd monitor, Mac doesn’t see it. Does this mean I need to update my ATI 5770 driver? And is that safe?
    Last question: with this ATI 5770 card being “Open CL” can I use my system ram for premiere or is this still a run on software only issue still? I’m running software only, cause I think my card isn’t supported. Does the new Premeire 8.0 support more cards like ATI 5770?
    Tom
    Tom Laughlin
    Producer/Editor
    Digital Chop House
  • Dennis Radeke
    October 15, 2014 at 3:13 pm
    [Tom Laughlin] “I guess my next question would be don’t you have to have some form of cuda or a cuda driver installed to run Davinci Resolve, or when you install DR, doesn’t it automatically place a cuda driver on your Mac?”
    Well, uh, I think you would want to ask the Blackmagic folks on that one…
    At the end of the day, CUDA is only for NVIDIA cards. You have an ATI card and CUDA won’t help you one bit. In Premiere Pro, you should have an option for OpenCL which is a cross platform technology which works with both NVIDIA and ATI cards that meet the proper specifications.
    Take a look at this and hopefully it helps you
    I would uninstall CUDA altogether unless DaVinci somehow needs it even in the absence of a CUDA enabled GPU.
    Dennis – Adobe guy
  • Robert Withers
    October 15, 2014 at 6:38 pm
    I used Open CL on my 2012 Macbook Pro with an Intel GPU for months after Pr CC 7.2.2 was released with no problems because I didn’t realize the CUDA card that is also in this machine card needed a driver 🙂
    Now using the CUDA but don’t sense any significant increase in speed.
    Robert Withers
    Independent/personal/avant-garde cinema, New York City
  • Kevin Monahan
    October 15, 2014 at 7:28 pm
    Hi Tom,
    [Tom Laughlin] “don’t you have to have some form of cuda or a cuda driver installed to run Davinci Resolve, or when you install DR, doesn’t it automatically place a cuda driver on your Mac?”
    Yes and yes. We fixed Premiere Pro CC 2014 (8.0) so that CUDA could co-exist on systems with Open CL GPUs. Update Premiere Pro, and this issue goes away. Until then, you should not have CUDA installed for Premiere Pro to run smoothly.
    Keep in mind that when you update to 8.0 or later, you must be running on OS X 10.8 or later.
    Hope that helps,
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Tom Laughlin
    October 15, 2014 at 10:48 pm
    Kevin, so you’re saying that adobe Premeire 8.0 can’t run on my Mac that’s running OS 10.7.5, is that correct?
    Tom Laughlin
    Producer/Editor
    Digital Chop House
