Activity Forums Adobe Premiere Pro CUDA on Mid 2014 Macbook Pro for Mercury Playback?
  • CUDA on Mid 2014 Macbook Pro for Mercury Playback?
    Posted by Scott Clements on June 11, 2015 at 9:31 pm
    I don’t know much about video cards, but would like to be able to utilise all the power my macbook pro can provide for Premiere CC. My understanding is that the Mercury playback engine in Premiere runs best using a CUDA card? I’m not 100 percent cure if I have one, but appear to on the surface. I need help confirming this.
    I see on the system report section on my mid 2014 macbook pro that under the graphics/ displays section, I have two listings for video card: 1. Intel Iris Pro/GPU/Built-In and 2. NVIDIA GeForce GT 750M/GPU/PCIe. Under system preferences, I have “CUDA Preferences” and seemingly the ability to install updated CUDA software.
    Does this confirm I have a CUDA card?
    Film Editor, London UK
    http://www.scottclementseditor.com
    Scott Clements replied 11 years, 3 months ago 2 Members · 2 Replies
  • Andrew Kimery
    June 11, 2015 at 9:48 pm
    CUDA is basically a proprietary software technology developed by Nvidia so if you have an Nvidia card (which you do) you can install and run CUDA. With that being said, AFAIK, the difference between using CUDA and OpenCL is minimal if you are using Adobe CC apps (older versions of the apps from CS 5 and CS 6 were either CUDA-only or performed much better with CUDA than with OpenCL). Some users are experiencing problems while trying to use CUDA (sometimes just having it installed can cause the problems) so, if it was me, I’d just stick with OpenCL until Nvidia can resolve the issue.
  • Scott Clements
    June 11, 2015 at 9:57 pm
    Great! Thanks for the info Andrew.
