Activity Forums Adobe Premiere Pro CUDA on Macbook Pro Retina?
  • CUDA on Macbook Pro Retina?
    Posted by Daniel Herter on May 3, 2013 at 11:19 pm
    Hi guys!
    From today I am the proud owner of a Macbook Pro Retina 15! Of course I would really like to use CUDA when editing in Premiere CS6. Now, I found this topic on the adobe forums where people are being warned for kernel panics when installing nvidia’s CUDA drivers.
    So I’m curious: who installed this and what problems do you experience?
    Cheers,
    Daniel
    Anthony Dean replied 12 years, 8 months ago 5 Members · 6 Replies
  • Paul Neumann
    May 4, 2013 at 2:00 am
    Use Mercury Playback Engine GPU Acceleration (Open CL). That’s all you need.
  • Tim Jones
    May 4, 2013 at 5:50 pm
    The latest drivers have been very stable for me under 10.8.3, however I see better performance with OpenCL.
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
  • Daniel Herter
    May 6, 2013 at 9:39 am
    Thanks for the reply’s guys! Can you tell me a little bit more why you prefer OpenCL? Do you also prefer this when using After Effects?
  • Tim Jones
    May 6, 2013 at 3:37 pm
    It’s not a preference in my case, it’s that the performance of the OpenCL settings are faster than the settings with the CUDA drivers.
    With AE, I believe that you’re going to have use the Cuda GPU drivers for the 3D work since without the Cuda “GeForce GT 650M” entry in the raytaracer_supported_cards.txt file, you will not get the GPU option in Previews. Also, pay very close attention to the Memory and Multiprocessing settings – with 16MB or RAM and the i7 processor, I use 5GB RAM reserved for other apps. Set CPUs reserved for other apps to 0, set RAM allocation per background CPU to 1.5GB. This will use 6 cores for your rendering.
    I’ve found this to be an acceptable configuration.
    HTH,
    Tim
    Tim Jones
  • Todd Bezenek
    July 25, 2013 at 6:37 pm
  • Anthony Dean
    January 17, 2014 at 5:31 am
    Hi Todd,
    What part of that link is relevant?
    Cheers,
    Tony
