Activity Forums Adobe Premiere Pro CUDA / Mercury Not Available on iMac (CC 2014)
  • CUDA / Mercury Not Available on iMac (CC 2014)
    Posted by Kyle Rebar on February 3, 2015 at 6:52 pm
    Hi all,
    I’m having some trouble with Premiere CC 2014. I’m using a late 2012 iMac with a GeForce GT 650M gpu.
    According to https://helpx.adobe.com/premiere-pro/system-requirements.html, I should be able to run Mercury GPU / CUDA fine.
    However, I can’t.
    The GpuSniffer returns * Not chosen because of insufficient video memory.
    I tried doing the old modify ‘cuda_supported_cards.txt’ workaround, but the file doesn’t exist in CC 2014.
    Has anyone else experienced this, or know what’s going on?
    Any help is greatly appreciated.
    Peter Garaway replied 11 years, 7 months ago 3 Members · 2 Replies
  • Tero Ahlfors
    February 3, 2015 at 7:22 pm
    [Kyle Rebar] “The GpuSniffer returns * Not chosen because of insufficient video memory.”
    Well your card doesn’t seem to have enough VRAM so it won’t work and you can’t enable MPE.
  • Peter Garaway
    February 3, 2015 at 7:43 pm
    Hi Kyle,
    Zero may be right. I believe the 650M comes with either 512MB or 1GB of RAM. Do you know which model you have? Premiere supports GPU acceleration with a minimum of 786MB of ram under that you will be unable to use the Mercury Playback Engine.
    Peter Garaway
    Adobe
    Premiere Pro
