CUDA Battle – MainConcept Codec Suite 5.1 vs. Premiere’s Mercury Engine
I’m using Premiere CS5 and have the Mercury engine GPU stuff enabled. When I export it goes much faster than when the Mercury stuff is disabled, this is incredibly clear as hours are pruned off the encode times.
Today I was informed by a friend that they use the MainConcept Codec Suite 5.1 plugins for Premiere CS5 which also uses CUDA for GPU-accelerated encoding.
Do you have any experience with this plugin suite or know of a speed comparison between it and Premiere’s native GPU-accelerated encoding?
– Hamst3r
The Hamster Alliance.
http://www.hamsteralliance.com
