Activity Forums Maxon Cinema 4D Cube with pictures
  • Cube with pictures
    Posted by Dan Roth on November 15, 2008 at 6:15 pm
    I want to create a cube with a different picture on each of its sides, but when i create a texture and import a photo into it and apply that texture to the cube, it automatically places that same picture on all six sides. Is there any easy solution?
    Also, where do you guys recommend i go to buy pre-made 3 models for c4d. (something not too expensive!)
    Dan
    Dan Roth replied 17 years, 10 months ago 3 Members · 3 Replies
  • Tom Hall
    November 15, 2008 at 9:24 pm
    ok 1.start by making the object editable
    2.use the ploygon tool and select one side of the cube(it well change color)
    3. with it selected go to the selection menu and click set selection,this will add a triangle in your objects tab next to the cube
    4.in the attributes window name the selection whatever you want…like (side 1)
    5.make your material with your pic or video in the color
    6. drag it into the cube in the objects window
    7. now in the attributes window ,where it says selection put in the name of the selections you made…..like (side 1 )
    Do this for all sides one at a time..just make sure when doing your 2ed side of the cube ,when your going to set the selection{MAKE SURE THE FIRST SELECTION TRIANGLE IS NOT HIGHLIGHTED} OR IT WELL JUST ADD BOTH SIDES TO THE FIRST SELECTION …GOOD LUCK
    cinema 4d
  • Adam Trachtenberg
    November 15, 2008 at 11:31 pm
    You can save yourself some time by making the cube editable, selecting a side, and then dragging a material onto the cube. Cinema will automatically set up a selection tag and assign the material to it.
  • Dan Roth
    November 16, 2008 at 2:16 pm
    thanks.
