Activity Forums Maxon Cinema 4D Cube with Image not crossing over to AE (C4D Lite)
  • Cube with Image not crossing over to AE (C4D Lite)
    Posted by Scott Eckley on July 27, 2013 at 5:36 pm
    I managed to ‘attach’ a JPEG to the side(s) of a cube an animated a camera to move it around (and other things). When I save the C4D file and go back into AE, the cube is ‘white’ on the sides – no picture. Back in C4D I have two lights (Omni) and no lights in AE. I’ve moved the lights around changed them to Spot – turned one off, the other off – it has no effect on the composition in AE.
    What is a bit frustrating (as I slide back Down the learning curve) is that it was working. I’ve used the undo to go back in history and can’t find where it was working. Given this is only my second day trying to use C4D, you can understand it when I tell you have no idea what I’ve done to “break” it.
    I’m hoping someone knows what I can do because they are much farther up the mountain than me. . .
    Scott (Atlanta, Ga)
    Scott Eckley replied 13 years, 1 month ago 2 Members · 2 Replies
  • Dan Conrad
    July 29, 2013 at 4:56 pm
    Are you “saving” in C4D before jumping back into AE?
    http://www.mographcandy.com
    Twitter: @mographcandy
  • Scott Eckley
    July 29, 2013 at 5:30 pm
    Well, it worked after quitting both programs and re-executing.
    Scott (Atlanta, Ga)
