Activity › Forums › Maxon Cinema 4D › Cube with deformer as a particle – either C4D emitter or x-particles
  • Cube with deformer as a particle – either C4D emitter or x-particles
    Posted by Gene Weglarz on May 5, 2016 at 12:18 am
    I’ve taken a cube. Used the bend deformer to roll it up like a roll of tape. I’m trying to use this as an object to be emitted by the emitter. Been struggling with this – can’t figure it out.
    10053_2016rollstouseasparticles.c4d.zip
    G. Weglarz
    MSI Intel I7 5960X 16 Core @ 4.4GHz; 32GB Ram;
    NVidia GTX 780ti; 60TB storage; Four Asus 27\” monitors
    Adobe CC 2015
    Cinema 4D R16
    Gene Weglarz replied 10 years, 4 months ago 2 Members · 2 Replies
  • Brian Jones
    May 5, 2016 at 12:42 am
    it will work for the default emitter if you check Show Objects – and it already works for xparticles
  • Gene Weglarz
    May 5, 2016 at 5:49 pm
    Oops. Yeah, forgot to show objects. With x-particles, I just need to figure out how to adjust so only 15 get generated, spacing, etc. Thanks!
    G. Weglarz
    Adobe CC 2015
    Cinema 4D R16
