Activity Forums Adobe After Effects Cube Transition
  • Cube Transition
    Posted by Rafael Cruz on September 30, 2009 at 4:46 pm
    Hi there,
    I want to create a cube transition. Imagine the screen divided into, say, 24 blocks. And those blocks rotate to reveal the next scene.
    Simple.
    I know I can do this by making a cube out of 6 3D layers, duplicating it, and parenting the layers to the face layer.
    What I want to know is, how can I really polish this?
    Here’s is an example of an beautiful cube transition (not rotating, but close enough) from istockphoto.
    https://www.istockphoto.com/stock-video-6693873-animated-fall-out-transition-hd.php
    I’m particularly impressed by the lighting. Any suggestions as to achieving that effect with that level of polish in after effects?
    or do i need to use 3D modeling software?
    Big thanks!
    David Bogie replied 16 years, 12 months ago 2 Members · 1 Reply
  • David Bogie
    September 30, 2009 at 5:15 pm
    to push the edges of the cubes into 3D as they rotate, yes, you must build them individually. It’s not particularly difficult to build one, duplicate it, replace the layers, and parent them all to one (or to a null or to an expression spinner).
    If you just need an elegant and lovely rotation transition, explore Card Dance and Card Wipe.
    Referring directly to the iStock sample, you can get Shatter to do this but controlling the z-space without getting an explosion is advanced.
    bogiesan
