Activity › Forums › Adobe After Effects › Cube in After Effects
  • Cube in After Effects
    Posted by Pete Davis on September 16, 2009 at 5:31 pm
    Hi, I am looking to make a cube in Illustrator or photoshop, bring the cube into AE and rotate it so I can see all 6 sides. Is making the cube in AI the best way to do this? Right now when I import the cube/AI file into AE it is flat. I know I am missing something just not sure what. I am trying to make a cube, have the cube rotate clockwise and place text wrapped around the cube going in the opposite direction.
    Thank you,
    Pete
    Jon Geddes replied 17 years ago 3 Members · 3 Replies
  • Todd Kopriva
    September 16, 2009 at 8:14 pm
    Several people have made scripts and projects that create or include 3D cubes from 3D layers.
    Community Help search for ‘cube scripts’
    Community Help search for ‘cube projects’
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Pete Davis
    September 17, 2009 at 1:20 pm
    Thanks Dave and Todd! I have decided to just create the cube in Boris/Avid FX a lot easier and by far fewer steps. I am creating the text in AE CS4 with help from the text preset
    ‘3d text on a circle’
    Thanks again!
    Pete
  • Jon Geddes
    September 21, 2009 at 3:09 pm
    I created a cube for our Texture Pack promo video seen here:
    https://www.precomposed.com/products/texture_packs/
    You will see the cube at 26 seconds into the video. You will notice I “slid” a texture onto the cube and spun it around, creating an interesting effect. This was done simply by using 4 surfaces, aligned in 3D space in AE, then parenting them to a null object (which was centered in the cube) for placement and rotation. The surfaces were precomps, and inside the precomps is where I slid the texture on.
    Jon Geddes
    http://www.precomposed.com
