Activity › Forums › VEGAS Pro › CTRL > G “shorthand”
  • CTRL > G “shorthand”
    Posted by Kelly Griffin on November 11, 2019 at 9:54 pm
    Is there an alternative (more convenient) way to enter a time address with CTRL > G that doesn’t require the ” : ” entry?
    In other words, if I want my play head to go to 1:28:53.20, on other systems I’ve worked on I could just type “1285320.” and it would know what I wanted.
    Does Vegas have a similar sidestep?
    Francois Pénzes replied 6 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Jorma Nippala
    November 13, 2019 at 11:54 am
    Have you tried it? Seems to work. Tried in VP 17.
  • Kelly Griffin
    November 13, 2019 at 6:11 pm
    “CTRL > G” works, sure…
    But my question is: Is there a way to not have to enter the colon, which requires both hands on the keyboard while entering the timecode?
  • Jorma Nippala
    November 13, 2019 at 6:41 pm
    Sorry, I must have misunderstood. I just used Ctrl+G, then typed 00002000 (or whatever), clicked Enter and the cursor moved to the desired position.
  • Graham Bernard
    November 14, 2019 at 5:36 am
    [Jorma Nippala] “I just used Ctrl+G, then typed 00002000 (or whatever), clicked Enter and the cursor moved to the desired position.”
    Yup, works here. No Colons required.
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Francois Pénzes
    November 15, 2019 at 3:13 am
    Hi Jorma and Graham
    I love a good mystery . On some of my projects, if I want to go to any position I always end up at the same point regardless of the numbers I type in. For example, I have a clip that has a total duration of 00:17:34.25. Whatever I type in, I always end up at 00:18:00.00.
    Then I open a different project with the same type of files and effects and whatever numbers I type in, it gets me there. 00172321 will go to 00:17:23.21. I have been able to reproduce Kelly’s problem but only on some of my projects. There has to be a smoking gun somewhere…
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Graham Bernard
    November 15, 2019 at 5:05 am
    [Francois Pénzes] “I have been able to reproduce Kelly’s problem but only on some of my projects. There has to be a smoking gun somewhere…”
    And NOW I’m very interested. Hmmm….
    Presently I’ve only come up with the Ruler Bar being different or QtF being ON or OFF. And even THAT doesn’t make any sense…. ? Can you interrogate each Project setup and determine ANY difference? What “appears” to be happening is a type of rounding-up going on and even that isn’t terribly scientific.
    Interesting… ????
    * Grazie
  • Francois Pénzes
    November 15, 2019 at 12:33 pm
    Hey Graham, think I found it.
    The difference that stood out from both is that in Files/Properties/Ruler one had Time & Frames and the other had SMPTE Drop (29.97 fps, Video).
    The one causing problems was Time & Frames. No problem using Control+G and getting to where I wanted to with SMPTE Drop (29.97 fps, Video) selected.
    Does it do anything for you Kelly ?
    P.S.: At some point and time, I will go thru all of them and see if any others have the same effect. Keep you posted.
    Cheers !
    Radeon RX 5700 XT
