Activity Forums Adobe Premiere Pro CTI stops when adding marker on the fly
  • CTI stops when adding marker on the fly
    Posted by Zvi Twersky on May 28, 2009 at 9:52 am
    I’m having problem with premiere pro cs3… when I set an unnumbered marker on the fly (while playing), the cti sets the marker but stops playing. This didn’t used to happen. I’m using cs3 and already tried resitting premiere with Shft and Ctrl… didn’t help.
    Any suggestions?
    Kell Smith replied 12 years, 2 months ago 6 Members · 8 Replies
  • 8 Replies
  • Ann Bens
    May 28, 2009 at 9:48 pm
    I had the same issue in CS4. Started a new project and problem disappeared.
  • Zvi Twersky
    May 29, 2009 at 2:37 am
    I came back from my coffee and it was working again! Strange.
  • Eddie Lotter
    May 29, 2009 at 2:03 pm
    Send Ann some of your magic coffee! 😉
    Hopefully the just released 4.1 update will help.
    Cheers
    Eddie
  • Diego Vasquez peñafiel
    August 21, 2012 at 4:37 am
    Try reseting your workspace to edit
  • Zvi Twersky
    August 21, 2012 at 4:39 am
    Thanks, but this was posted three years ago! I use CS6 now and don’t have this problem.
    August 21, 2012 at 4:44 am
    Yeah but some people may still use older versions of premiere, and might find this useful
  • Rupert Peddle
    February 11, 2013 at 8:53 pm
    think i’ve figured this one out! well, in CS5.5 at least 😉
    it seems that if you have the same clip as currently playing in the program monitor selected in the source preview monitor, playback of the program stops when you add a marker on-the-fly. if you load another clip into the preview monitor, playback of the timeline continues when adding markers…..weird eh! can anyone else confirm this work around?
  • Kell Smith
    July 9, 2014 at 11:03 pm
    Yes, what I found was that when I double-clicked the audio clip in the timeline, loading it into the source monitor, and then added markers on the fly, the clip stopped. But when I double-clicked the actual clip in the project panel, opening it in the source monitor, the markers were easily added with no stopping.
    I’m working in a buggy old copy of CS5.5 and there are a lot of little derailments like this – but I’m working the way through each one.
    Hope this helps someone out there.
