Activity Forums Adobe After Effects CSV Data Driven Expressions Overtime
  • CSV Data Driven Expressions Overtime
    Posted by Simon Allmark on March 19, 2019 at 6:09 pm
    Hi, I’m a bit stuck and need your help clever people.
    I’m trying to use an expression to show data from a CSV file.
    essentially linking the data values of a graph as text as a line scrolls across the graph.
    Ideally, I need the individual parameters data changing every frame.
    I have imported the CSV and can get this expression to show me the individual parameters if I manually edit the dataValue but I can’t seem to work out how I can get it to pull the different data every frame when I play the timeline.
    footage(“Dinjector out0001 DATA001.csv”).dataValue([1,1])
    I’ve tried linking it to a slider that numbers up each frame but no luck and this is a bit more complicated than my knowledge of expressions currently stretches too.
    Any ideas on how to do this would be much appreciated.
    thanks
    Simon
    Simon Allmark replied 7 years, 6 months ago 3 Members · 4 Replies
  • Michael Szalapski
    March 19, 2019 at 10:49 pm
    Does putting time into your expression help? That’s how I’d count up each frame.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Simon Allmark
    March 20, 2019 at 8:23 am
    Hi Thanks for the suggestion, I tried to use time but I couldn’t get it to work, possibly just a syntax error but no luck so far.
    I also tried to use a slider to control the Column and Row and the Row counting up but again it’s not working, it could be a simple error in my code,
    X = thisComp.layer(“Expression”).effect(“Time”)(“Slider”)
    Y = thisComp.layer(“Expression”).effect(“Time 2”)(“Slider”)
    Value = footage(“Dinjector out0001 DATA001.csv”).dataValue([X,Y])
    my hunt continues!
  • Walter Soyka
    March 20, 2019 at 2:51 pm
    If you want a new value each frame, try something like this:
    footage("Dinjector out0001 DATA001.csv").dataValue([1, timeToFrames(time)+1])
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Simon Allmark
    March 22, 2019 at 8:53 am
    That’s exactly what I needed, works great.
    Thanks for your help
