Activity › Forums › Web Design (WordPress, Joomla, etc.) › CSS/HTML Errors
CSS/HTML Errors
Posted by Jeff Kelley on July 7, 2008 at 12:58 pmHello,
I’m correcting all the errors that I’ve got at a HTML Validation site. This is one I can’t figure out. Can you Help?
JeffSapphire Parker replied 18 years, 2 months ago 3 Members · 5 Replies -
Curtis Thompson
July 7, 2008 at 5:03 pmhello…
i’d try dropping the space between the “=” and the next quote for the first one – and wrt type – you need to add text/javascript if you want to be in full compliance…
https://www.w3schools.com/TAGS/tag_script.asp
hope that helps!
sitruc
Jeff Kelley
July 7, 2008 at 5:08 pmThanks Curtis,
A big help, as always. One more, how about this?
Error Line 357, Column 7: XML Parsing Error: Premature end of data in tag body line 23.
Curtis Thompson
July 7, 2008 at 5:09 pmhello…
ooh – this one is pretty much impossible to say w/o seeing code… :-/
note too that none of these are bad per se – if you are trying to be very strict and correct with your html then they are good to fix, but they won’t impact much else…
sitruc
Jeff Kelley
July 7, 2008 at 5:17 pmThanks. I won’t embarrass myself or bore you with coping my code. Thanks for all your help. Probably have some more soon!
Sapphire Parker
July 31, 2008 at 2:02 pmReplace your script tag with this one
Hope this helps!!!
Cheers,
Sapphire https://www.videoediting-direct.co.uk
