Activity › Forums › Web Design (WordPress, Joomla, etc.) › CSS Image Overlay with Linked Text
  • CSS Image Overlay with Linked Text
    Posted by Ken Walton on November 3, 2010 at 7:28 pm
    I’m running into a problem recreating an easy to pull off “print” effect one of our designers came up with for a site I’m working on.
    I’ve got a fixed-height, scrollable sidebar that shows an unlimited number of event/news entries (via PHP), but I need the bottom 15% or so of the div to “fade to black”. I’m halfway there, as you can see on this semi-static example here:
    https://mh1webdesign.com/~kirkbaue/dev/gradientTest.html
    The problem is, I need my linked text “behind” the overlaid PNG to remain linkable/selectable…
    PS. this example is just page text – no php calls or scrolling yet. It seems like the solution should work the same way on either though.
    Thanks in advance –
    Ken Walton
    Fernando Mol replied 15 years, 10 months ago 2 Members · 1 Reply
  • Fernando Mol
    November 18, 2010 at 6:15 pm
    Well, theoretically you could add your gradient as a background graphic to an empty span element that’s in front of your text box.
    I have seeing this effect in some experimental sites.
    You'll need this CSS
    .yourGradient h1 span {
    background:url("/linkToYourGradient.png"); //You may want to position it
    display:block;
    height:300px; //the height of your text block
    position:absolute;
    width:100%;
    I hope this helps
