Activity › Forums › Web Design (WordPress, Joomla, etc.) › css drop down menu overlap swf
  • css drop down menu overlap swf
    Posted by Jez777 on September 27, 2006 at 7:16 pm
    I want to have a nav menu that expands over a swf that keeps playing.
    It seems that even when just laying a div overtop of a swf, the swf rises above the div when the swf starts moving. I tried using z-index of course. Is there anyway to fix this? Thanks.
    Jez777 replied 20 years ago 2 Members · 2 Replies
  • Curtis Thompson
    September 27, 2006 at 7:22 pm
    hello…
    very known issue and there are hacky fixes at best (the hacks aren’t bad in this case – it’s the flash dom layer issue that requires hacks to get around it)…
    the cheap fix is wmode=transparent, but that can cause problems in some flash animations based on content – and it won’t work for all browsers…
    there are other tricks, but note that it will almost never work in safari on os x – you’re kinda stuck there…but try googling up wmode and transparent or the parent issue can be seen here:
    https://www.google.com/search?q=dhtml+over+flash
    and the main macromedia doc on it:
    https://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_15523
    hope that helps!
    sitruc
  • Jez777
    September 27, 2006 at 7:35 pm
    Thanks for the lightning fast response. I’m in the right direction now. wmode set to transparent does help alot. Safari is my browser of choice, too bad it sux for this 🙁
