Activity Forums Adobe Premiere Pro CS6 XML works in After Effects and doesn’t work in Premiere
  • CS6 XML works in After Effects and doesn’t work in Premiere
    Posted by Terry Leahy on January 25, 2017 at 11:23 pm
    Hi guys,
    Getting frustrated. Running CS6 and exported using the Premiere XML option in DaVinci Resolve. Opens fine in After Effects but will not open in Premiere. Any thoughts? Anybody else have this stupid issue? I have even tried saving the after effects file and importing that but it won’t work. Pro Res Media I don’t get it.
    Terry Leahy replied 9 years, 6 months ago 1 Member · 2 Replies
  • Terry Leahy
    January 25, 2017 at 11:45 pm
    Figured it out. Adobe is just an asshole. You have to start a project and then import from the source browser and click selected sequence and then it works.
    Cheers!
  • Terry Leahy
    February 23, 2017 at 3:35 pm
    Needed to add this! You need to open the XML in After Effects, then save it as a premiere project AND THEN import the premiere project from the media browser.
