Activity › Forums › Adobe After Effects › CS6 Won’t Render AVIs Properly (Includes YouTube Video of Problem)
  • Ivan Myles
    September 3, 2013 at 7:16 am
    Please post your AVI export settings. What is the source footage?
  • Chris Kay
    September 4, 2013 at 3:03 am
    Render Settings
    Quality: Best
    Resolution: Full
    Disk Cache: Read Only
    Porxy Use: Use No Proxies
    Effects: Current Settings
    Solo Switches: Current Settings
    Guide Layers: All Off
    Color Depth: Current Settings
    Frame Blending: On for Checked Layers
    Fiel Render: off
    Motion Blur: On for Checked Layers
    Time Span: Work Area Only
    Use Comp’s frame rate: 29.97
    Format: AVI
    In Format Options I selected None for Video Codec
    Channel: RGB
    Depth: Millions of Colors
    Color: Premultiplied (Matted)
    Checked Audio Output
    48 kHz
    16 bit
    Stereo
    The original file I was rendering was a .MTS file (AVCHD Video), 1440 by 1080. I really need this format to work because one of my cameras records in this format.
  • Chris Kay
    September 10, 2013 at 2:03 am
    The original file (.MTS) I was referring to was the file I was working on in After Effects. Not the file I created in a render.
    Before you mentioned how you would “make something lossless like a QT in the PNG codec, and then transcode it into AVI.” What’s the best way to go about doing this?
