Activity Forums Adobe Premiere Pro CS6 UnCompressed Quicktime w/ Alpha Channel
  • CS6 UnCompressed Quicktime w/ Alpha Channel
    Posted by Jayson Palmer on August 24, 2014 at 2:34 am
    Is there a way to render out an uncompressed/ high quality Quick Time YUV 8 Bit 4;2:2 file with a working Alpha Channel from Premiere Pro CS6? Thank you.
    Ericbowen replied 12 years ago 8 Members · 9 Replies
  • 9 Replies
  • Oliver Peters
    August 24, 2014 at 12:58 pm
    No. By definition uncompressed codec QuickTime formats don’t carry alpha channels. Animation or ProRes4444 codecs can carry alphas (millions+ setting). I’m not sure if Premiere Pro lets you export with an alpha (I don’t think so), but you can do it from After Effects. A second option would be to generate separate matte and fill exports as two different files. Those could be two uncompressed QuickTimes, but would need to be synced/composited later when you use them again.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Tero Ahlfors
    August 24, 2014 at 2:44 pm
    [Oliver Peters] “I’m not sure if Premiere Pro lets you export with an alpha”
    It’ll work. You’ll need to pick a supported codec and set it to maximum bit depth in export.
  • Alex Udell
    August 24, 2014 at 5:07 pm
    I think it also has to be on Video track 2 or higher with nothing on Video track 1.
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Ann Bens
    August 24, 2014 at 5:48 pm
    Quicktime set to Animation and 32 bits will give you a file with an alpha channel.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Robert D’alexis
    August 24, 2014 at 8:44 pm
    [Alex Udell] “I think it also has to be on Video track 2 or higher with nothing on Video track 1.”
    It ain’t necessarily so. 🙂
    You can produce files with an alpha channel irrespective of the track hierarchy using QT Animation + as Ann pointed out or uncompressed AVI files 32 bits (on Windows).
  • Ivan Myles
    August 25, 2014 at 1:03 pm
    [jayson palmer] “Is there a way to render out an uncompressed/ high quality Quick Time YUV 8 Bit 4;2:2 file with a working Alpha Channel from Premiere Pro CS6?”
    Note that the uncompressed QuickTime codecs with Alpha channel support are RGB color, not YUV (YCC). ProRes 4:4:4:4 might be a good alternative.
  • Ericbowen
    August 27, 2014 at 2:39 pm
    DNxHD in Quicktime if the Avid codecs are installed would give the Alpha option as well. Lagarith is another but that is AVI if the req is Quicktime.
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
  • Ivan Myles
    August 27, 2014 at 3:55 pm
    DNxHD/MOV is prone to luma clipping and shifts. I no longer recommend using it. DNxHD/MXF in Creative Cloud is OK, though.
  • Ericbowen
    August 28, 2014 at 2:37 pm
    That would be the Quicktime player version used to decode. Otherwise the MXF would have the same problem. I would test it with the updated player version for that platform before eliminating.
    Eric-ADK
    Tech Manager
