Activity › Forums › Apple Final Cut Pro › CS6 to FCPX .xml file
  • CS6 to FCPX .xml file
    Posted by Adam Chesbrough on August 30, 2012 at 3:33 pm
    I have read that it is possible to export an .XML from Premiere Pro CS6 and import it into FCPX. For some reason when I try to import the .XML into FCPX the premiere XML file is greyed out. Am I missing something here or is CS6 .XML simply not compatible with FCPX?
    Macbook Pro Retina
    2.6GHZ i7
    16GB RAM 1600MHz DDR3
    OWC 4TB RAID0 (using esata)
    Tempo SATA Pro ExpressCard/34 (3Gb/s)
    Echo ExpressCard Pro Thunderbolt Adapter
    Mark Maness replied 13 years, 10 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    August 30, 2012 at 5:00 pm
    It is not.
    You should try 7toX (in the app store) to translate the XML to FCPXML.
    Jeremy
  • Mark Maness
    November 28, 2012 at 3:45 pm
    I’ve found out that it ONLY works if you have basic cuts and dissolves AND no video filters or effects applied. For the most part… Its useless for “real world” work. Great for simple offline to online cuts.
    _______________________________
    Wayne Carey
    Schazam Productions
    schazamproductions@mac.com
