Activity › Forums › Adobe Premiere Pro › CS6 to DaVinci workflow (render clips for DaVinci)
Posted by Andy Kolb on May 21, 2013 at 11:50 amBefore I keep struggling with this topic I thought I’d ask on here.
I have a timeline (CS6) with a bunch of After Effects sequences, speed ramps and so on.
Obviously these things don’t transfer to Davinci Resolve when I’m doing the traditional XML workflow.That’s why I want to render/export all clips (without compression of course) and bring them into Davinci.
Like I said I’ve never done that before and I don’t want to spend many hours to find out by myself.
Drew Lahat replied 13 years, 3 months ago 3 Members · 4 Replies -
Ryan Patch
May 22, 2013 at 5:15 amUnfortunately, there is no workflow to transcode all media in timeline and “bake in” effects like you can in Avid. With the ease of integrating Dynamic Link into your editing process, this generates this new problem when you need to go to DaVinci, yes.
There’s two options: export a “baked in” whole timeline and then use shot detection / EDL to cut the shots back up in Davinci. This is painful if you have fades, though.
Other is this: Delete every timeline from a project except the one you will color. Duplicate this sequence. Save as NEW project file.
Remove all effects from new sequence, import this sequence into Davinci. Manually add source files from AE comps. DO all color without effects on clips. Export clips. Relink clips in Premiere project. You can also duplicate AE files, relink to colored source media in AE comps and to new AE projects in Premiere (if you duplicated). Re-apply speed effects, copy and pasting from original sequence you duplicated if they’re fancy or complex.
It’s a pain the butt, but that’s the way to go. Basically, if I am doing anything that I know is going to Davinci, you need to wait until AFTER color to do heavy work on it. That’s just the way the pro toolset works. You can do everything out of order, free-wheeling and neauveux-editing style… but it limits you when you want to use pro tools like Davinci or Protools. There’s a post workflow that is followed for this reason – there’s only a certain number of effects that translate between programs.
Ryan
Ryan Patch
May 22, 2013 at 5:16 amI do agree, though, that there should be some sort of media manager that allows you to “bake in” AE comps that you’ve embedded.
Andy Kolb
May 22, 2013 at 9:19 amThanks for the good reply.
This is not really what I wanted to hear but at least now I know.Since I was in a rush I graded this project in Redcine-X but next time I will try to grade in DaVinci and then do the speed adjustments after.
Drew Lahat
May 24, 2013 at 10:55 pmI’m writing this as I’m supposed to be conforming a PPro project for Resolve 🙂
We do plenty of effects and transitions in our edits, so every round-trip process is quite a PITA. It is doable though.As far as the “right” way to do this with a “pro toolset”, I talked to Stephen Nakamura a few months ago – he’s a colorist at Level3 whose recent work includes Prometheus and Zero Dark Thirty. While discussing Prometheus, he said that he got the materials to grade AFTER everything – VFX, compositing and all. That’s been my understanding – that the proper way to do this is effects before grading. What we have to do with PPro & Resolve is a technical limitation, not the proper industry way. I’d be happy to hear otherwise.
(Stephen even said that he doesn’t deal with individual comped elements – it’s the VFX dept job to balance them and he gets the flat comped shot to grade once.)
