Activity Forums Adobe After Effects CS6 Time Ruler shows all frames and not seconds regardless of how I’m zoomed…
  • CS6 Time Ruler shows all frames and not seconds regardless of how I’m zoomed…
    Posted by David Stack on June 14, 2013 at 2:39 pm
    How do I switch the time ruler to show seconds? Whether I’m zoomed all the way in or out all I see are frames. I’d like to know where the 4 or 9 second mark is without having to do the math. Why have they made something so simple so difficult?
    MOBO: ASUS P6X58D-E/Intel Hex Core i7 970/RAM: 16GB/Microsoft Win 7 Professional, 64bit/GeForce GTX470/System drive: Western Digital VelociRaptor, 10,000RPM/DECKLINK HD EXTREME/SONY BETA SP DECK, PVW-2800/Premiere Pro CS5
    Michelle Mclane replied 11 years, 3 months ago 3 Members · 5 Replies
  • Ivan Myles
    June 14, 2013 at 3:08 pm
    Not sure if this works in CS5, but in CS6 CNTL-Click on the frame number in the composition panel to toggle between frames and timecode.
  • David Stack
    June 14, 2013 at 3:16 pm
    LOL, Dave you had no idea how much that Africa comment speaks to me. I was born in Nairobi, Kenya and have been back there and Tanzania. And thanks for the quick response!
    Back on subject: I’ve done some Googling and searching in forums over this before posting and everything keeps taking me back to Project Settings>Time Display Style options. But no matter what combination I have in TDS (Footage Start Time, Use Feet + Frames, Frame Count, etc.) I still cannot get the seconds to display. What am I missing?
  • David Stack
    June 14, 2013 at 3:39 pm
    Yes, I’m in CS6 and when I toggle back and forth I’m still not seeing seconds. When I’m back to frames that’s all I see.
    Here’s a screen print. Again, no matter how I’m zoomed in, I don’t see seconds…
  • David Stack
    June 14, 2013 at 3:57 pm
    I’ve got an answer! A co-worker figured out that I had to close After Effects and re-open while holding down Shift+Ctl+Alt to delete the preferences. And it worked! I don’t know how I got into that mess, but I know how to get out. Thanks anyway!
  • Michelle Mclane
    June 12, 2015 at 8:46 pm
    I was having the same problem as David, but I figured out that I was too zoomed in to the project. Above where it says “f” after the number, grab the the right-most little handle and pull it toward the right. I believe you can also use your – key (and maybe shift or something else? Sorry, I’m new) to zoom out. Once you zoom out, you should see the information in seconds. The reason it shows frames when you zoom in is because frames make up a fraction of seconds. Hope that helps!
