Activity Forums Adobe After Effects CS6 Strange square around my object effects
  • CS6 Strange square around my object effects
    Posted by Abner David rodriguez on October 26, 2013 at 3:24 am
    I’m trying to make my own Universal Studio logo intro but it seems that the shine from the “Light Burst” it’s limited by a dark square. I’ve tried different picture size, different compositions as well but i can’t find any solution to get rid of that square or make it bigger so my effects can be shown further ahead. If anyone knows how to fix this PLEASE help me i’m really trying to be my best with this program.
    Ridley Walker replied 12 years, 10 months ago 3 Members · 6 Replies
  • Ridley Walker
    October 26, 2013 at 4:06 am
    Can’t see from the screen shot but my suspicion is that the Precomp layer is square and what your’e seeing is the layer boundary.
  • Abner David rodriguez
    October 26, 2013 at 4:38 am
    If you see in the screenshot, around the globe the shine comming from the continents is supposed to be extended longer into the screen, but that small black square frame around the globe doesn’t let the shine effect be seen completly.
    abner david
    October 26, 2013 at 4:43 am
    the problem i’m trying to solve is the small square around the globe(earth). The shine comming from the continents are supposed to be longer & extended forward aside out the screen, but if you look closely the end part of the shines comming from the continents cannot be seen further because a small square frame is blocking it.
    abner david
  • Chris Brett
    October 26, 2013 at 11:48 am
    Hi — precomp the earth and make sure the precomp is the same size as the main comp – not the size of the earth.
    Apply raye to new precomp — this will probably sort it….
    All the best ——chris
    October 26, 2013 at 4:18 pm
    it seems that the problem might only be the Ligjt Burst effect, other effects go ahead further to the screen except the Light burst. Any suggestions to fixing that?
    abner david
  • Ridley Walker
    October 26, 2013 at 8:05 pm
    What version of After Effects are you using?
    Here is a screen grab from CS6.
