Activity Forums Adobe After Effects Expressions cs6 scripting – toggle all proxies – can’t find a “ProxyExisting” value
  • cs6 scripting – toggle all proxies – can’t find a “ProxyExisting” value
    Posted by Adam Seeley on November 2, 2012 at 4:28 pm
    Help! 🙂
    I’m very new to scripting in AE (Although have used lot’s of OM type stuff using VB in Softimage).
    I want a simple script to toggle all proxies on & off.
    I’ve dragged my slowly melting brain as far being able to loop through all project elements & turn proxies off, as AE will turn a proxy off whether or not one exists.
    I haven’t found a way to test if there’s an existing proxy to turn one again. The script will stop if there’s no existing proxy attached to a project item.
    Any help would be gratefullt recieved.
    Cheers,
    Adam.
    // ams_ToggleAllProxies.jsx
    // This script one day will toggle all proxies on & off.
    function ams_ToggleAllProxies()
    clearOutput()
    writeLn("ams ToggleAllProxies");
    var oItems = app.project.items;
    var totalItems = oItems.length;
    var temp=1
    writeLn("Number of items is: "+ totalItems)
    for (var i=1; i<oItems.length; i++) {
    $.writeln("item:[" +i+ "] is " + app.project.item(i).name);
    $.writeln("proxyFlag:[" +i+ "] is " + app.project.item(i).useProxy);
    // I WANT TO CHECK A VALUE OF THE PROXY PATH TO SEE IF A PROXY EXISTS BUT I DON'T KNOW HOW.
    //$.writeln("type:[" +i+ "] is " + app.project.item(i).proxySource.path);
    // JUST AN "IF" FOR WHEN I HAVE A PROXY-EXISTING TYPE VALUE TO TEST.
    if (temp=1)
    $.writeln("AAGHH")
    // THIS DOESN'T WORK WHEN NO PROXY EXISTS AND STOPS THE SCRIPT
    app.project.item(i).useProxy=true
    // THIS DOES WORK AND TURNS OFF A PROXY WHETHER THERE'S ONE IN USE OR NOT - HALF WAY THERE
    //app.project.item(i).useProxy=false
    alert("Proxies Toggled")
    ams_ToggleAllProxies();
    Adam Seeley replied 12 years, 8 months ago 3 Members · 5 Replies
  • Dan Ebberts
    November 2, 2012 at 7:03 pm
    I haven’t tried it, but I think you should be able to do this:
    if(app.project.item(i).proxySource == null) continue; // skip to end of loop
    Dan
  • Adam Seeley
    November 9, 2012 at 1:26 am
    Brilliant, thanks for that…. works perfectly.
    Always tricky getting just the right syntax when your’e learning a new language.
    I now have two scripts, one for turning all proxies on & one to turn them off.
    I can’t believe it’s not already a feature for a hotkey!
    Thanks again,
    Adam.
  • Tilmann Schneider
    December 1, 2013 at 12:31 am
    would you be able to post these two scripts?
    I’m looking for exactly that and can’t find it anywhere.
    That would be great!
    Til
  • Adam Seeley
    December 5, 2013 at 9:54 pm
    And why not…
    Here’s the script to Toggle All Proxies OFF
    Save it into
    ams_turnAllProxies_OFF.jsx
    and stick it into the
    C: -> Program Files -> Adobe -> Adobe After Effects CS6 -> Support Files -> Scripts”
    Folder
    Hope it works for you,
    Adam.
    // ams_ToggleAllProxies_Off.jsx
    //adam_seeeley@yahoo.com
    // This script one day will toggle all proxies on AND off.
    clearOutput()
    writeLn("ams ToggleAllProxiesbbb");
    var temp=1
    //if(app.project.item(i).proxySource == null) continue; // skip to end of loop
  • Adam Seeley
    December 5, 2013 at 9:56 pm
    And for turning them all on again…..
    save into a text file:
    ams_turnAllProxies_ON.jsx
    Hope it helps.
    Adam.
    // adam_seeley@yahoo.com
    clearOutput()
    var temp=1
