Activity › Forums › Adobe Premiere Pro › CS6 PrPro performance on MacBook
Posted by Alan Stephens on December 9, 2012 at 9:25 pmI have just upgraded to CS6 on my MacBook Pro which has the Nividia card.
Do I need to do anything to take advantage of the mercury playback engine? My first test seems to run better than before.Mac Book Pro 2.6, quad i7, 8 GB Ram, NVIDIA GeForce GT 650M 1024 MB, OS X Lion 10.7.5
Thunderbolt Promise raid driveAlan Stephens
Alan Stephens replied 13 years, 9 months ago 3 Members · 9 Replies -
Alex Gerulaitis
December 9, 2012 at 10:37 pm650M is supported by Pr 6.02/03, so I’d just confirm you have “MPE GPU acceleration” in project settings, and if so, you’re all set.
Alex Gerulaitis
Systems Engineer
DV411 – Los Angeles, CA -
Tero Ahlfors
December 10, 2012 at 8:42 amThe acceleration should be on by default if you have a supported card in your system. Check the project settings like Alex said.
Alan Stephens
December 10, 2012 at 8:46 pmI checked the project settings but it is greyed out. I says “Mercury playback engine software only”
How can I enable it?
It does however have very good playback in real time at 1/2 rez setting. I took a clip and applied a B&W filter to the background then key framed a blur. At the same time I over layed another clip at half size applied a bevel and keyframed motion across the screen and it all plays smooth.
At full rez playback it does stutter. This seems pretty good for a MacBook!Alan Stephens
Alex Gerulaitis
December 11, 2012 at 8:33 amWhat version Premiere Pro (6.0? 6.03?), NVidia CUDA driver are you running?
Alan Stephens
December 12, 2012 at 5:28 pmI am running PrPro 6.0.0
CUDA 5.0.36 however when I checked I noticed an update is available.
After running the update I now have CUDA 5.0.37
The render option is still greyed out, but I can’t complain about the performance. It is great!
So I can assume its working at its best?Alan Stephens
Alex Gerulaitis
December 12, 2012 at 10:09 pm[Alan Stephens] “I am running PrPro 6.0.0”
Update CS. Premiere Pro should be 6.03.
Alex Gerulaitis
Systems Engineer
Alan Stephens
December 12, 2012 at 11:37 pm -
Alan Stephens
December 16, 2012 at 6:02 pmUpdating software and drivers solved this inquiry.
Thanks for your help!
Alan Stephens
