Activity Forums Adobe After Effects CS6 Performance Impressive!
  • CS6 Performance Impressive!
    Posted by Brian Charles on June 6, 2012 at 12:05 am
    I’ve just rendered a file in CS6, wow. CS5.5 rendered in 4 hrs 20 min, CS 6 rendered in less than half the time. Holy Shxt!
    I suspect Steve Forde (formerly GridIron Software) had something to do with this. As a former Nucleo Pro user I’m really impressed with the memory management and performance of CS6.
    MacPro 12 core 32 GB RAM. OS 10.6.8
    Jeffrey Broullire replied 13 years, 2 months ago 5 Members · 6 Replies
  • Roland R. kahlenberg
    June 6, 2012 at 2:12 am
    It is easily the best software upgrade I’ve ever made.
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Spencer Tweed
    June 6, 2012 at 4:25 am
    Wow! What kind of disk is your performance cache on? And what GPU do you have?
    – Spencer
    June 6, 2012 at 9:44 am
    Here’s some good info on render times with various hardware-supported ray-tracing with CS6 –
    https://twitter.com/rendernyc/status/208421894792298496/photo/1/large
    However, there are other considerations as to the type of comp/layer setup. But the results do give a good indication as to which cards to avoid and which ones give the most bang for the buck!
    HTH
    RoRK
  • Kevin Reiner
    June 6, 2012 at 1:42 pm
    Good to hear Brian,
    Makes my upgrade decision earlier. As far as multiprocessing, does AE 6 do all of the guesswork for you in regards to preferences?
    I just finished a huge project with AE5 that was helped tremendously by multiprocessing, but at times I felt I was spending more time figuring out the optimal preference settings rather than creating.
    Reiner
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    ATI Radeon HD 5770
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.6.5
    FCP 7
    After Effects CS5
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
  • Brian Charles
    June 6, 2012 at 3:19 pm
    [Kevin Reiner] “As far as multiprocessing, does AE 6 do all of the guesswork for you in regards to preferences? “
    I had mine set to use 7 processors allocating 3GB to each.
    I looked at Activity Monitor during the render, RAM was freed quickly and reallocated. Cache was set to 40 GB on a RAID 0 (2 x 1TB 7200 rpm drives).
  • Jeffrey Broullire
    July 3, 2013 at 11:00 pm
    hello, @ Brian Charles (or other users of nucleopro3)
    don’t know if this will work
    but can you reply back stating where to ‘install’
    gridiron nucleo pro 3 licenses please…
    thanks in advance, have a good day, j
