Activity › Forums › Adobe Premiere Pro › CS6 Multicam Question
  • CS6 Multicam Question
    Posted by Angelo Lorenzo on April 15, 2012 at 6:56 am
    If anyone knows, is multi-cam in CS6 able to play the master or submix from the nested sequence? Or are the audio tracks still strictly ganged to their corresponding cameras?
    One work around I’ve done is to unlink the nested sequence and only enable multi-cam on the video portion, so the audio plays with the full master track. The disadvantage is that none of the multicam cuts transfer to the audio so I have to manually cut it if I want to trim air out of the sequence.
    Kevin Monahan replied 14 years, 5 months ago 4 Members · 5 Replies
  • Alex Udell
    April 15, 2012 at 12:34 pm
    Todd’s video seemed to indicate that it came from audio track 1 of the source sequence. So stack your cameras so that the audio you want comes is edited from track 1 in the source sequence.
    Alex
  • Ron Pestes
    April 15, 2012 at 6:36 pm
    Yes, I think that is correct. But doesn’t CS 5.5 do it that way too? It seems to me that is the way I did my last multicam a few months ago.
    ronpesteshdvideo.com
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    Dell M6600
    New convert to Adobe CS5.5 Production Premium
  • Angelo Lorenzo
    April 15, 2012 at 8:20 pm
    Yes, CS 5.5 does it the same way: if you cut with the multi-cam monitor the audio track stays locked on audio one (or, more likely whatever camera you start the recording with). If you adjust clips later on by right clicking and assigning new cameras, if the audio is linked, then the audio will be assigned to the new camera; i.e. if you right click and select camera four and the audio is linked then the audio will switch to audio track 4. If you noticed my original post, it’s why I unlink the audio as part of my multi-cam workflow.
  • Ron Pestes
    April 15, 2012 at 8:25 pm
    Very good point about unlinking. I forgot about that.
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Kevin Monahan
    April 16, 2012 at 7:23 pm
    Yes, it works the same way.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
