Activity Forums Adobe Premiere Pro CS6 Multi-Camera Source Sequence
  • CS6 Multi-Camera Source Sequence
    Posted by Eddie Torre on July 31, 2012 at 11:55 pm
    I have a few quicktime movies and a few AIFF files.
    When I select just the quicktime movies and r click, I can get the “Create Multi-Camera Source Sequence” option.
    When I select just the AIFF files and r click I cannot get the “Create Multi-Camera Source Sequence” option (greyed out)
    When I select a combination of the two and r click I cannot get the “Create Multi-Camera Source Sequence” option (greyed out)
    Is there something I am doing wrong? I’ve tried syncing via in-points and by markers and haven’t been able to get a multiclip source clip going that involves audio only tracks.
    Thanks for any help.
    Norman Greenwood replied 14 years, 1 month ago 2 Members · 1 Reply
  • Norman Greenwood
    August 13, 2012 at 5:17 pm
    Just in case I’m wrong, I am thinking that you want the AIFF files to be synced with the movie files?
    If so, try linking them together first and then the option for multi-camera.
    The only other way I understand this is that you are trying to use the multi-camera option on audio files, which I don’t think works.
