Activity › Forums › Adobe Premiere Pro › CS6 Effects rack Peaking ?
  • CS6 Effects rack Peaking ?
    Posted by Jeff Dean on April 28, 2015 at 9:17 pm
    A little confused hopefully someone will have the answer. I tried posting in the Audition forum but no one had an answer. Thought I would try here.
    Using CS6. Imported sequence from PP into Audition.
    Normalized audio to -6 db. Added a hard limiter at -4db in the effects rack.
    My Meter levels at the bottom of the audition screen are perfect.
    My Meter levels in the effects rack are peaking/going into red.
    Why is the effects rack showing me a different level than the main meters at the bottom – is it just showing me the levels before the hard limiter takes effect?
    Thanks for any help.
    Jeff Dean replied 11 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
