Activity › Forums › Adobe Premiere Pro › CS6 can not play Audio AVCHD from Lumix GH2
  • CS6 can not play Audio AVCHD from Lumix GH2
    Posted by Terry Tsangaris on June 1, 2012 at 11:44 pm
    CS6 can not play Audio from AVCHD Codec shot on Lumix GH2 Video will run fine,MJPEG setting plays both A/V.
    The same Files Play in full on CS5.5
    Has anyone encounter this Fault with other Codecs or is it specific to GH2’s Codec.
    I do have the Latest updates for CS6,Running on WIN-7 64bit.
    I noticed Premiere Has Taken away a lot of the TimeLine Presets,But they have added a Confirm to Clip Specs requester,Same as FCP 7.
    Adobe please fix this minor glitch to you cause it’s a MAJOR problem for us ASAP.
    Well It’s Back to CS5.5 to Finish My Project.
    Terry
    Nathan Ifans replied 14 years, 3 months ago 3 Members · 2 Replies
  • Ann Bens
    June 2, 2012 at 12:29 am
    You need to copy the entire folder content from the card to the harddrive
    then import via the Media Browser.
    For the presets try this:
    Start Premiere Pro. Create a new project and new sequence. Close Premiere Pro. Restart.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Nathan Ifans
    June 27, 2012 at 9:38 pm
    When you created the project, did you sleect AVCHD as the sequence preset? Or was this not present, and you chose DVCPROHD or similar instead???
